here
If this is under £30 Id buy one. I seriously doubt it will be though.
This would be ideal though as it will silence the 360 for multimedia use.
doesn't it invalidate your warenty though?
Which with the xbox's is quite an important thing isnt it?
In my personal experience MS will fix a 3RLOD no matter what has happened to the 360. Although I imagine you'd have to put the 360 back in its original shell.
this thread isn't about 360 returns policy but about the case.
But whats the point in the case.
It would hopefully be silent when in the dashboard which would allow me to use it as a media centre for high definition wma.
Like I said anything above £30 and then it is pointless.
in that case make one out of mdf.
Your looking at towards 100 notes for that case i believe its lian-li, and plus are you willing to risk your warranty?
You remove the xbox from its chassis you break the seal and you can forget warranty lian-li wasted time doing this to be honest.
My seal is intact despite my 360 currently being run as just the motherboard sitting on my desk![]()
Don't own a camera![]()
)Don't own a camera![]()
