My V2000B is built like a tank.
1,2mm so actually thicker than 1mm of high end steel cases.My old a70 seemed to have quite thin panels
From what i have heard, the cheaper lian li cases ie, pc7 etc are made with slightly cheaper aluminum than the more expensive ones ie v1000z or something.
Still it shouldnt be a problem...is it a real issue or is it just one of those things that you may or may not notice?
