Lian pc 7 HDD layout
1 Mar 2007
Portsmouth
Just brought an extra 500GB HDD to add to my 250GB. Having a bit of trouble deciding where is best to put them. Iam guessing the bay in the middle, would be ok as it fits x2 drives but iam sure they would be too close together.
Whats wrong with having them close to each other?
Unless it's a part of the case that requires airflow to be good, then i wouldn't have thought there would be any problems.
as long as there is room for the air to move around you shouldnt have a problem
Yer I dont think there is hardly a gap, they pretty much sit on top off set other.
I would like them both the the bottom area, but the FAudio cable is too short so its been run between this area.
Those who have a ds3 and lian pc 7 case, has anyone found a good way off arranging x2 HDD's bare in mind that the FAudio cable is very short with this case and the gfx card shortens the length even more.
