- 24 Feb 2007
ive got all my new system working fine and this case is quite nice but theres 1 or 2 things that dont seem fantastic
1 - the drive plates dont allow you to put an additional hard drive in the internal 3.5 bay properly because of their clips that stick out. You can still fit a drive in there but its sort of hanging out
2 - the removable hard drive cage has 2 problems as far as i can see. Firstly you cant possibly access all the screws on the other side due to the motherboard not having a tray. secondly if you take the cage out and put the drives in, you cant screw the cage back in because of drive overhang?
3 - fans dont have LEDs like i expected, no big deal but would have been nice.
4 - had to pay an extra £15-20 or something to get the window which i realise you have to do on some other cases, just seems a bit pointless in not giving you the option of buying 1 with it already on instead of having a spare side panel
Its not a complaint thread everything apart from those is great but i just wanted to see if others experienced the same issues with the case
