Hi everyone,
Does anyone have any idea of what lifespan I should expect from a DDC Pump? I've had my PC under watercooling since 2020 and my 2nd pump has just failed. The first one was the Alphacool and the second was the EK (4.2 PWM). Should I expect them to fail this often?I have three radiators, 1x 120, 1x 240 and 1x 360. Both the CPU (5800x) and GPU (2070s) are water cooled and I have the glacier r160 as my reservoir and pump mount. The case is a NZXT H710.
Its my first water-cooling build and apart from my pump issue its been flawless. If I need to remove something then more than happy to take everyone's advice and i'll modify.
Cheers all!
