Light gaming laptop
12 May 2012
Hi all,
I've been looking at a couple of the Dell 15" 7000 Gaming Laptops
Option 1 - £1000
Core™ i7-7700HQ Quad Core (6MB Cache, up to 3.8 GHz)
16GB Single Channel DDR4 2400MHz
Dual drives with 256GB Solid State Drive + 1TB 5400 rpm Hard Drive
NVIDIA GeForce GTX 1050 Ti 4GB
15.6-inch FHD (1920 x 1080) Anti-Glare LED-Backlit Display
Option 2 - £1200
512GB PCIe NVMe M.2 Solid State Drive
15.6-inch UHD (3840 x 2160) IPS Anti-Glare LED-Backlit Display
Which one would people go for? Or something else?
Thanks in advance.
+ display - FHD LED versus UHD IPS. Not too fused about the two storage options but seen some bad reviews on the LED screen, not sure whether the IPS is worth an extra £200?
Screen is ghastly on them. You'll need the UHD panel. I love the look of the laptop but that's classic mistake number 1 - buying something because it looks cool. :p
