Light gaming rig
22 May 2010
Minibotpc
Hey guys, just want to run this through with you before i make the purchase. I'm building a light gaming rig for my bro as his laptop isn't up to its job at the moment. He's on a low budget and i have a few parts left over from my old build aswel which i will use in the process. Just wanna make sure there aren't any compatibility issues with these components so if you could just do a quick run over or offer any good or better alternative components please let me know, thanks!
SPEC:
Asus M4A78LT-M 760G (Already got)
Phenom II 955 BE 125w
Asus Silent knight cpu cooler (Already got)
2x2GB Corsair XMS3 DDR3 1333mhz Ram
CD/DVD combo drive
1TB WD 7200 HDD
Powercolor 5670 512mb (Already Got)
(not chosen make yet) 300W PSU
OcUK RaidMax Simplex Gaming Tower Case - Black
Budget of about £300 excluding the parts i already have for the build.
Thanks
Jay
But is 300w more than enough for this rig? He's not wanting an upgrade at all in the future. This will be a gap filler before he buys his own proper rig in a few years time.
I went ahead and used the Antec PSU calculator, and 300W seems to be borderline acceptable for that rig, Personally, I would have gotten one a bit more powerful just to be sure. Possibly a 400-500W or 300-400W if you're on a lower budget.
This is a good budget gaming system. If it's a habit you want to look at the Phenom II. The price should be similar, but it works better than the Q8000 Phenom II. 9800GTX + is a decent card and should be more than enough to play with the settings and maximum resolution.
Might just be able to push it to a 400w psu. Not quite sure which brand to go for yet as I haven't had a proper look. The phenom II 955 BE 3.2ghz surely is more than enough for this light gaming rig. I already have the gfx card so I don't need to buy another. Does anyone recommend a good 400w psu please?
I'm not sure yet, i haven't looked but atm the 400W antec seems a really good price. I would get those if i could but i already a graphics card for use in this build left over from my last build so there is no need to buy another gpu.
