Light strip for TV
8 Dec 2004
Hampshire
I saw the Philips Hue strip but this is available on for 55" and upwards.
Is there anything similar? I bought something from Amazon many moons ago but the lighting is quite weak.
hmm problem with the philips is the tv mounts are quite big and not enough place to mount them on the back of the LG C2 42".....
B&M as in the shop B&M?
Would you like me to type that into Google for you? Search engines are very hard and complicated after all, will give you a head start
Look for govee
Look for govee
Yes Ive seen govee, but wasnt keen on this sensor protruding from the top (already have a light bar across the top of my monitor).
Thank you for your assistance to help my googling skills :)
You only get the pack with the sensor if you want a cheap ambilight effect, normal govee works fine (it's what I have, though I should have gotten a larger kit for my 65")
Really? the packaging doesnt seem to indicate this.... are you sure?
Any alternatives you would consider?
If they are the "play" addressable light strip then no you can't cut them down, they are sized to fit from bottom left of the rear of the TV around the top and so on to the bottom right, there is a little triangle on the strip which should then be at tdc of the TV as it's accurate to the colour on screen you can't cut or adjust it.
I have the 65" play strip along with 3 play bars below the tv (behind a low av cabinet pointing upwards) coupled with the hue sync box, it's awesome during movie night, brightness wise it's about 30% otherwise it's too bright. At all other times just the light strip is on behind the TV at about 15% brightness running a hue multi theme (colour run) at a slow speed.
Stupidly expensive but bloody gorgeous.
Just re-read your op, I think your looking at the wrong hue strips the TV sized ones are play strips designed for use ideally with the sync box. The other type are 2mt and non addressable. These are on offer on the hue site at around 55 pound at the moment, you will also need a hue bridge to use them properly
I have or had the Philips Hue strip, they work great. Until I got a Philips OLED with the light strip built in which reacts to the image on screen, then it's at another level, that feature is worth like £100 alone!
(Or you can turn off the reacting and keep it constant)
I just bought a cheap set off Amazon for a 42" TV, RGB including three different types of white. Works great in the consveratory think it cost me £14.95
Shame Dreamscreen got swolled up Philips and then made to dissappear, didn't like the competition. I have the 4k version, works really well, no stupid camera over the tv
The problem with the decent ones is they're not very smart tv friendly, and what I mean by that is you can't watch directly on it. It needs to be fed through HDMI to know what colours are displayed where.
True, everything goes through my AV, then into the dreamscreen
