Light Sudo lockdown
12 Oct 2005
Surrey
I have a group that has super user privileges (/etc/sudoers ALL etc..) (which will be locked down slowly).
How can you stop users switching to other users account (thus stopping audit trail)?
Stop them from using the su command?
Hello ;)
Right, check out /etc/pam.d/su and uncomment:
auth required pam_wheel.so use_uid
Add your users to the wheel group.
Root by default is a member of the wheel group, so you could then remove root from this group. Although, I'm unsure if that would break anything...
You might also want to look at creating a command specification in sudo and blocking it that way...
Why aren't you sipping coctails by the beach!
:D
Thanks! It's all kicking off here ;)
Hello ;)
