- 19 Dec 2003
- UK
Hey folks,
When I moved in to our house just over a year ago I started to change the light switches from the white plastic type, to the chrome / metal style ones with plastic switches.
At the time, I realised I needed to add an earth to them, as the plastic ones did not need them but metal ones would etc.
Anyhow, with some of them, this was straightforward, there was no earth cable in the wiring, so I just added a small piece of earth cable, covered in a sheath, and screwed it to the metal backbox, and then to the earth-port on the back of the light switch.
I noticed on some of them, there was an earth wire already inside the set of wires, so you had a wire to common, wire to L1/L2, and then an earth wire going to the backbox.
So what I have done with those ones, is add an extra earth cable from the back of the light switch earth port, and then screwed it to the backbox where the existing earth cable is going, is this correct? Or should I have simply removed the earth cable from the backbox and plugged it straight into the back of the light switch earth socket? I guess it can't do any harm as it is, but I just wondered what the correct way would have been?
(I did notice there were existing metal switches in the kitchen, that had not been earthed prior to me replacing them!)
Edit - see my latest post, I HAD done it correctly all along
