Light switch for Hive
25 Mar 2003
Birmingham
Is there any way to get a light switch for Hive similar to the one that Hue do?
I also have Alexa if something can be integrated in to that to switch off the Hive lights.
Obviously I can do all this from the app/voice control but sometimes when you walk in to a room it's just easier to press a button.
No switched available for hive unfortunately, Google home and Amazon echo have plugins for hive though. Why not add a movement sensor and itttt for movement when it's dark to put the light on?
Yeah I have the Alexa plugin and I have a motion sensor elsewhere - just wondered if I could get say, a Hue dimmer switch and set that up through Alexa to switch the light on and off?
I know hue and hive can function together but not sure how to be honest although it's something I intend to find out soon.
