Replacing light switches in the house and hit a snag, annoying as changed all the others without problem.
Tried switch elsewhere and works OK.
Will try to break it down as simple as I can.
One bulb in the hallway, one bulb at the top of the stairs.
Double switch downstairs, one switch controls hallway light.
The other controls the one at the top of the stairs. The switch at the top of the stairs should control the upstairs light only.
What is happening now is the switches have become messed up, controlling wrong light, if one is on, you cannot turn off the other.
I have screwed up, I know but what is the problem, the L1, L2 cable positions in the switches? How do I narrow it down?
Thanks.
Thanks.
