- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hi.
I have had my hallway decorated and during the process the light switches were left disconnected, well they were connected but as the walls were replastered there was hanging and some of the wires have come out.
I have a 3 gang switch downstairs which is:
Switch 1 = Porch
Switch 2 = Downstairs hall light
Switch 3 = upstairs hall light
Then I have a single switch upstairs on the wall that is for upstairs hall light
The problem I have is the switch 3 for the upstairs hall light is not working at all, I can switch the light off/on with the other single upstairs located switch, but the 3 gang switch downstairs for it doesnt work.
What have I done wrong with the wiring? Any ideas?
This switch works fine for the upstairs light.
This below image of the switch is the downstairs switch which is NOT working for the upstairs light, the switch that isnt working is the right most switch of the 3 the one with the yellow/blue and red cables. Any ideas what is wired up wrong? I don't know which switch and which wires are wrongly wired up.
Switch 1 = Porch
