Light tent
19 May 2004
Just in the process of adding images to my online store for the products I make and having photographed these products at different times and locations it's very noticeable that there is no continuaty in the photos. Can't spend a lot as funds are tight.
Are the packages on amazon ok or is it better to get lights separate?
What size are the products? You could always make a makeshift setup, white paper backdrop, couple of desk lamps and a couple of paper diffusers to shine the lights through.
Try ebay , they have table top photography kits at quite reasonable prices for the continuous light set ups. I bought a 80 x 80 cm light tent from there for £14 ! and use it to photograph my aircraft models after building, using a couple of D-Lite 400w strobes.
