- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys,
Want to save money? Upgrade your home lighting to LED technology. There is an inital cost involved, however the average home can ave around £700 per year on their electric bills with these fully kitted out. These bulbs have a rated life-span of over 15 years.
Emprex Bayonet Fitting LED Light Bulb @ £21.98 inc VAT
The B101 Emprex LED Bulb is your first step on the road to saving money at the same time as helping the environment. With approximately 10 times the lifespan of a standard household bulb and an impressive energy saving of around 80% the Emprex B101 LED Bulb is the perfect solution to all your lighting needs!
- 10 times Approx the life span of a standard bulb (Lifetime up to 35,000 hours)
- Saves approx 80% more energy compared to a standard bulb
- Instant light up without delay or flicker
- Anti UV/IR
- Contains no mercury and fully recyclable
- Improved breakage resistance due to reinforced plastic and aluminium body design
- Power Consumption: 4.5W (Typical)
Only £21.98 inc VAT.
ORDER NOW
Emprex High Efficiency 2 Foot LED Light Tube @ £29.99 inc VAT
Emprex LED Tubes provide high brightness and low power consumption and will easily replace your current conventional fluorescent tube light. Using super-bright LED's and premium components, these are a stunning example of LED engineering providing flicker-free operation and instant start up. They also work without ballast or a starter, thus saving further energy!
- Long life (up to 40,000 hours at ambient temperature 25oC)
- Low power consumption, saving energy and money
- No starter needed, replaces the traditional fluorescent tube directly
- Compatible with T8/T10 lighting fixture
- Instant light-up with no flicker
- Aluminium alloy body helps better heat dissipation
- No UV or Radiation
- No pollution and recyclable, ROHS compliant
- LED Type: SMD3020 LED x 120pcs (Daylight)
- Temp: 5600~6300K (Daylight)
- Base Type: T8 or T10 fitment
- Input Voltage: 100~240 VAC
- Power Consumption: 9W (Typical)
- Power Factor: >70%, 85% (Typical)
- Operating Temp: -30oC ~ +45oC
- Storage Temp: -40oC ~ +80oC
- Illumination Angle: 140o
- Lumen: 680 lm (Typical)
- Colour Rendering Index: 70%
- luminance: 240 Lux (4 tubes at 2M Height)
- Housing: Aluminium alloy + PolyCarbonate
Only £29.99 inc VAT.
ORDER NOW
Emprex High Efficiency 4 Foot LED Light Tube @ £39.98 inc VAT
- Low power consumption, saving energy and money (18W (Typical))
- LED Type: SMD3020 LED x 240pcs (Daylight)
- Power Factor: >70%, 80% (Typical)
- Lumen: 1352 lm (Typical)
- Luminance: 350 Lux (3 tubes at 2M Height)
Only £39.98 inc VAT.
ORDER NOW
- Anti UV/IR
ORDER NOW
ORDER NOW
ORDER NOW
