Lighting advice please
31 Dec 2005
Always on the M1.....
Would appreciate some advice from anybody with respect to taking pictures of somebody who has a less than prominent chin. I find it really easy to make it look worse than it actually is!
I currently have a single 580 II, but am thinking about getting another second hand flash or a remote trigger to use it off camera. I don't want to spend a fortune on new kit (or at least any more than I already have!).
Any thoughts would be appreciated.
bounce it off of a reflector or shoot through a large diffuser/softbox to soften the light, and have it be really close (if softened) and underneath their chin - but not close enough for the nose to start casting shadows over the forehead etc.
So on camera with reflector underneath?
Oh you don't have triggers? Okay on camera, bounce it off of a white wall or similar roughly horizontal and 90 degrees away from the subject, and have a reflector set up on the other side of the wall you're bouncing off of to give a little extra fill on the light to soften it all out?
Do you mean so the light is coming in at 45 degrees to her on the horizontal, from both sides?
Something along these lines
Alternatively you could pick up one of those cheap beauty ring adapters and then sparingly use the heal brush in photoshop to soften the lines a bit if that's the problem?
PS sorry my handwriting is still god awful with the tablet haha
Thought that was what you were saying. Nice impromptu drawing!
Bought a 580 a couple of years ago before a relative's wedding and found it so useful for getting pictures you just can't do with on camera flash (which I haven't got now anyway). Makes such a difference, but still struggle to sometimes avoid making pictures a little unflattering!
Basically just bounce off of any white wall or ceiling you can find and sort out your compositions so that this works is a fairly easy rule of thumb to work by to begin with. I very very rarely have flash directly on subjects as, as you said, it gets very unflattering and I can't be bothered to buy softboxes etc. - if I desperately need them for something I'd sooner just make them myself in any case.
