- 25 Apr 2011
- Crawley/Gatwick
Morning guys
As usual i have one of them crazy ideas. I recently bought CM 690II advanced black/white case. It has been kitted out to the max, almost.. still 3 140mm vipers to come and couple fan guards. As with storm enforcer, i ripped out hdd cage for better airflow, all my stuff is in drive bays. Also planning to add 140mm to the bottom. Nevertheless, if you are familiar with the case, there is a button that turn on and off lights on the front fan. I will remove the fan as i don't like it. What i want to do with the button is keep it, and use it to turn lights on and off. Only problem i am facing is finding lights which i could connect that button to, its 2 pin. few years back i had 2M of NZXT lights, but cant remember if they take 2pin, i mean if i connect case 2 pin instead of the thing that comes with it
any ideas? maybe someone already done simmilar thing? please help
TA
