Lighting Node Core Not Detected
17 Feb 2009
Got two lighting node cores connected to one commander pro.
Commander pro is plugged into the internal motherboards USB header.
In iCue it only detects the commander pro and not the node cores.. Any ideas ?
Does this have something to do with it ?
RGBs on the fans are running and I can control fan speed in iCue but not the RGBS
Always worth swapping out the sata cable, and check you have fitted the cable correctly in the same sata port on the motherboard.
Ok if I type in “exit” it boots up windows.
Must be something to do with my old Linux install. Probs get rid of the SSD soon anyways and just run the M.2
Thats all sorted. But I can't seem to see my node cores in iCue. any ideas ?
After some reading, it appears the " USB Passthrough " on the Commander Pro malfunctions with some motherboards.
Will try a 4 way USB Internal adapter and see if that works
All sorted.
Needed a seperate (powered) USB hub as apparently the Commander Pro's USB passthrough isn't powered by the PSU but instead the motherboard.
