Right, I've just gotten into a debate with a friend over how lightning rods work, and I got bored arguing, so want you lot to do it for me (May as well be blunt
I didn't know too much about lightning rods before this started, I thought they simply attracted lightning strikes so they hit the rod, and didn't hit other things such as buildings. But from what I can now tell, they don't exactly attract it, just the lightning looks for the lowest resistance to ground, which is the lightning rod, so it strikes there and goes into ground, job done. However, she's saying that:
So... any takers for either side? Using the theory that the simplest solution is often the best, I claim that I'm right, but am I?
Thanks
)I didn't know too much about lightning rods before this started, I thought they simply attracted lightning strikes so they hit the rod, and didn't hit other things such as buildings. But from what I can now tell, they don't exactly attract it, just the lightning looks for the lowest resistance to ground, which is the lightning rod, so it strikes there and goes into ground, job done. However, she's saying that:
What happens is the dense electric field around the tip of the rod wards lighting away from the immediate area. It doesn't provide a low resistance path to the ground because if the lightning rod works right, it prevents the lightning from striking at all!
Thanks
