Lightroom preset help / advice
11 Oct 2005
Derbyshire
Hi
Looking for some help finding presets that are similar to these. Or advice on best way to adjust my images to something like these.
Hopefully the link works.
I'm using Lightroom
Thanks
Emily Soto has/had some free presets that were along those lines of aesthetic, but the bulk of anything like that lies with the VSCO preset packs. There are lots and in the past I tried out 4 VSCO packs to narrow down my old skool 35mm Leica film inspiration to then build my own custom presets using those as a baseline. Might be worth the investment if you are looking to also build your own signature style and to start with use another preset to base things off from.
