LIKE with IN/list of entries
18 Oct 2002
Hi all,
I have a query whereby i need to return some entries from a table but the actual field is a string comprising other elements, such as a date. That means i need to do some sort of like, but also with an IN/list of entries. Having produced the script SQL Server Management Studio is telling me that the subquery is returning more than 1 record, which is true, but is there any way around this. See query below:
Code:
select ah.changedate, ah.ChangeDescription, ah.UserName, ad.Auditid, ad.sourcekey, ad.OldValue, ad.NewValue
from AuditDetail ad,
     auditheader ah
where ah.AuditId = ad.AuditId
AND ad.sourcekey like CONVERT(VARCHAR(20),(select distinct individualpolicyid from SplitBillingLink AS SB inner join Policy AS POL
		on SB.EmployeeCategoryPolicyId = POL.PolicyId where PolicyStatus = 'L' and IndividualPolicyEffectiveDate = EffectiveDate)) + '~19%'
order by ad.Auditid
any help much appreciated.
Many thanks,
B@
If you're in control of the data then you shouldn't really have a column which contains multiple pieces of information like that.
Assuming you're not in control of that data, could you JOIN on the subquery data and then use LIKE in the JOIN clause? e.g.
SELECT FROM xxxxxx INNER JOIN SubQuery ON SubQuery.individualpolicyid LIKE ad.sourcekey
Code:
WITH SourceKeyCTE AS
	SELECT
		DISTINCT CONVERT(NVARCHAR(20),individualpolicyid) + '~19%' AS [PolicyID]
	FROM
		INNER JOIN
			Policy AS POL
			ON
	WHERE
SELECT
	  ah.changedate
	, ah.UserName
	, ad.Auditid
	, ad.sourcekey
	, ad.OldValue
	, ad.NewValue
	, sk.PolicyID
FROM
	auditheader ah
	LEFT JOIN
		AuditDetail ad
		ON
	LEFT JOIN
		SourceKeyCTE sk
		ON
			ad.sourcekey LIKE sk.PolicyID
WHERE
	sk.PolicyID IS NOT NULL
ORDER BY
	ad.Auditid;
I have made some assumptions but would this work for you?
If you then wanted to see one record for any potential matches then you could just simply group the results.
