Hi I recently purchased a laptop with a built in intel pro wireless 2200bg network card. To cut a long story short the computer is having trouble obtaining an ip address( it is coming up with 169.xxx). I thought it was a problem with the hardware until i tried it at school and found that it worked perfectly. I then went home and tried it directly plugged in via ethernet and usb both coming up with the same problem. Everytime windows tells me that there is limited or no connectivity
I have tried the following steps:
Winsock fix
Windows update ( the one that is meant to make it work after installing sp2)
Reinstalling wireless
Reinstalling Tcpip
Reinstalling ethernet port
changing settings to 10mbps on the ethernet
The wireless is without wep or wpa authentication so it should work fine my dads powerbook works fine on it i am at a loss at what to do. PS it is telewest cable broadband
Any help would be appreciated
THNX
Winsock fix
Reinstalling Tcpip
THNX
