limited or no connectivity when wireless
Caporegime
18 Oct 2002
London
My friend is trying to set up his wireless network but when ever they try and connect to the router via wireless it says "limited or no connectivity". He says he has checked the router settings to see if dhcp server bit is disabled but it isnt. Using XP (SP2 on all machines) and a Netgear dg834g. Any ideas?
normally means the secruity settings do not match
ie: the router wants a WEP/WPA key and your not putting in the right details
