"Limited or no connectivity"
8 Oct 2005
Midlands, UK
Hi,
got my 360 connected to a 10/100 LAn port. The new connection shows as Limited or no connectivity in the taskbar. I have tried renewing the ip adr with no luck...any ideas?
thx
I don't have a 360 but I do very occasionally get this message from my wireless connection. When I do a repair on the connection doesn't work so I have to turn my router off then on again. Might be worth a try if you haven't already tried it.
Edit: although I've just reread your thread and so it will probably have no effect :rolleyes:
