Limited or no connectivity?
14 Oct 2009
UK
So i have just bought a dell netbook and when i try to connect to my network it says that i have limted or no connectivity but my ps3,wii and laptop all work fine....I went back to shop and they tried it there and it worked fine...He then suggested i change the channel of my wireless router? That sound right? ......Any other things i can do?
I would actually try updating the wireless drivers first. I encountered a similar problem with a slightly older Dell Inspiron machine that with a certain driver revision refused to connect to my wireless network. Everything else worked perfectly, and when I went to a previous driver, it connected absolutely fine.
I've had this issue numbers of times with the wireless on my parents PC. I find that sometimes rebooting the router works a treat.
What router? My DG834GT sometimes is a bit funny with handing out IP addresses (DHCP enabled) to even wired stuff so i've manually added IP addresses to my kit and it works fine. The DHCP playing up is a known bug with the DG834GT.
