Limited overclock with 2000mhz memory
14 Jan 2010
Essex
Hi, I had an email recently regarding a build where i was considering putting 12gb 2000mhz RAM in, I was replied to by one of the suppliers that i would be lucky to see 3.4Ghz overclock on a 980x, now considering stock speed is 3.33Ghz, is this true or is he pulling my chain.
I have heard of the limits to overclock with that amount of Ram, but i don't understand why? please could someone set me straight
What is your motherboard - and what ram are you planning on using. I have overclocked my 980X on the Gigabyte GA-X58-UD7 and UD9 boards with 12 GB or ram while testing. But I am not going to pretend that it was an easy task at all. The major factor for me was the quality of my imc of my CPU.
the facts...
chances are you will be able to get the 12gb memory to 2000mhz
chances are you wont be able to do this with a significant clock on the cpu
if you are new to clocking then you definatly wont be able to do it.
i clock around 70 computers a week and i think i would probably struggle to get 12gb or memory stable with a gulftown running at 4ghz+
the only way it will be remotely easy is if your cpu has an exceptional IMC
my 970 does 12gb at 2000mhz nice and tight but will not get those kind of memory speeds past 3.8ghz
The thing to bare in mind is that a matched set of tri-channel ram will not have the same over-clocking characteristics per stick. So when you have twice as many sticks of ram the equation becomes so much more complicated.
4 Ghz is pretty good going as an over clock with 12 Ghz. Not that many people will get it right with tight ram settings.
Well, a family memeber got a 980X with 12GB of 2000Mhz RAM. It was overclocked by another company and is all cooled by a corsair h50.
End result is the RAM is clocked at 2250 Mhz and the CPU is running at 4.2Ghz and the temps are in the 60-70deg range under load.
Also worth noting the mobo is the asus P6X58D-E.
So yes, it is possible. As for how easy it is to do, no idea.
yes it is, thats why i said it was
so why do you have:
if you dont know how to clock it? :confused:
Becuase I have what I have, Im allowed to buy the equipment I choose, and surely something your passionate about doing, I should be free to learn and enjoy doing it surely?
Yes but his point is that you shouldn't start out HUGE like you are, but start with inexpensive equipment so it doesn't matter if you blow something to pieces.
There is another way of looking at the whole thing too. The RE3 motherboard has heaps and heaps of options that maybe are not going to be used by 98% of all RE3 owners, and all those extra options and settings choices do is add to the confusion to a new user. However once you have worked out how to master your new motherboard I can promise you not that many other boards will ever confuse you again.
Good luck - but start with the basics first and in no time you will have it. Over-clocking a i7 cpu is not that hard because there are so few settings that need to be changed.
I won't blow it to pieces becuase Im not gonna do anything without seeking advice and doing research, I will also not be overlcoking stupid amounts either trying to push every last mhz out of the chip.
screenshots tbh
True it is not 2000MHz on the ram but still pretty impressive from this German chap.
Code:
http://valid.canardpc.com/show_oc.php?id=799178
Full cup-z showing a 12GB set of ram.
Not a 980x by the looks of it and close is not 2000mhz
So very true. The CPU-z link I posted was more to do with the fact you can overclock a CPU with 12GB of memory. I really should have been more clear.
If you recall the OP and what was asked.
