Hi, hoping someone can help.
So the background of this is our landline broadband is slow and always will be, lately 4G speeds blow it out the water so I'm considering a 4G/5G router. But the cap on an 'unlimited' connection is 1000 GB a month. Looking at usage stats for the last year on our broadband, most months are between 4-500GB, some are up to 800GB. I imagine more bandwidth would be used with the higher speeds.
So let's say I go with it, the EE 4/5G routers are quite limited so what device do I want between the router and the rest of the network that would give me control over bandwidth to the outside?
The ideal set up would be limiting bandwidth on whatever the DHCP range is and then devices with unlimited bandwidth can have a static address. I'd have to turn off its WiFi and use a different access point too.
Thanks.
Thanks.
