limiting Excel save as extensions
6 Mar 2008
Stoke area
Hi all,
I've got a work spreadsheet that needs to be edited by some other people who are less competent (read "retarded") and then saved as a .xlsm file.
They open it as a .xlsm file, but seem to constantly be saving as a .xlsx instead, despite numerous emails and adding a massive header the sheet telling them so.
So, my question, is there any code I can use to make it impossible to save as anything but an .xlsm file?
EDIT: PLEASE SEE POST #3 for a new issue :)
Typical, spend 30 mins googling and find nothing.
Post here.
Find something online :D
Code:
Private Sub Workbook_BeforeSave(ByVal SaveAsUI As Boolean, Cancel As Boolean)
Dim fName As String
fName = Application.GetSaveAsFilename(, "Excel Macro-Enabled Workbook (*.xlsm), *.xlsm")
If fName = "False" Then
MsgBox "You pressed cancel", vbOKOnly
Cancel = True
End If
Application.EnableEvents = False
ThisWorkbook.SaveAs Filename:=fName, FileFormat:=xlOpenXMLWorkbookMacroEnabled
Application.EnableEvents = True
End Sub
Ok, small issue with the above code.
if you click save and click cancel you get a msgbox "you pressed cancel".
It then automatically saves it as False.xlsm. Anyway to stop it?
I'm no Excel macro expert, but try this:
Code:
	Dim fName As String
	If fName = "False" Then Exit Sub
End Sub
The new 'Exit Sub' part should stop the execution of the following code which does the saving of the worksheets.
