- 11 May 2006
Hi,
I currently have a P5Q Pro + Q9550 pro at 3.4ghz using DDR2-800 ram.
I'm trying to get above that, but as soon as I do, I quickly get errors in prime95.
Looking at the bios I think the problem stems from my ram, which seems to overclock automatically with the fsb. For example, if I set fsb at 450mhz, ram also overclocks to 450mhz. Also in the dram frequency options (under AI tweaker menu), there is no setting to go below the fsb speed, e.g. at 450mhz fsb, the lowest dram frequency is DDR-900.
I'm thinking there has to be some sort of fsb:ram divider, but I can't find it. Any ideas?
Some help would be greatly appreciated!
