- 25 Sep 2003
- Manchester
I have a very old DG834G v2 with the latest firmware, our internet here is not so good, with it reporting the following line stats:
Connection Speed
down: 1536 kbps
up: 768 kbps
Line Attenuation
down: 61 db
up: 15.5 db
Noise Margin
down: 15 db
up: 7 db
It shows the line attenuation as 61db and I thought perhaps a newer router might have a better chance at helping the attenuation so I bought a brand new DG834GT and put the DG Team firmware on it.
The DG834GT with DG Team firmware reports a line Attenuation of 63.5 db!
Could this be due to the way it reports back, i.e. there is no actual change it's just the numbers reported are different or could it be that for some reason the older DG834G is just better for the critical (in my case being a long line) Attenuation?
I'm not sure if I should leave my old DG834G v2 there or replace it with the newer one with custom firmware as I believe the higher attenuation will maybe lower my speeds further than they already are over time?
Connection Speed
down: 1536 kbps
up: 768 kbps
Line Attenuation
down: 61 db
up: 15.5 db
Noise Margin
down: 15 db
up: 7 db
