I've been with o2 now for 2 months & basically it does drop randomly & I was wondering would interleaving being put on help (noticed it was not on after doing the telnet check)
stats below (just need help before I ring)
BusyBox v1.00 (2007.11.05-06:13+0000) Built-in shell (ash)
Enter 'help' for a list of built-in commands.
# adslctl info --stats
adslctl: ADSL driver and PHY status
Status: ShowtimeRetrain Reason: 8000
Channel: FAST, Upstream rate = 1265 Kbps, Downstream rate = 13321 Kbps
Link Power State: L0
Mode: ADSL2+
Channel: Fast
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 6.1 6.5
Attn(dB): 26.5 12.3
Pwr(dBm): 18.4 12.4
Max(Kbps): 16834 1261
Rate (Kbps): 13321 1265
G.dmt framing
K: 95(0) 36
R: 14 0
S: 1 1
D: 128 1
ADSL2 framing
MSGc: 59 16
B: 94 35
M: 1 1
T: 4 3
R: 14 0
S: 0.2461 0.9762
L: 3542 295
D: 128 1
Counters
SF: 30712 30687
SFErr: 12 3562
RS: 7985122 0
RSCorr: 6592 0
RSUnCorr: 481 0
HEC: 12 1913
OCD: 0 0
LCD: 0 0
Total Cells: 15456702 3523624558
Data Cells: 12236 275018480
Drop Cells: 0
Bit Errors: 0 176005
ES: 5 2392
SES: 0 0
UAS: 38 2778
AS: 492
INP: 2.02 0.00
PER: 16.00 16.10
delay: 7.87 0.24
OR: 32.49 10.92
Bitswap: 44 5
Total time = 9 min 2 sec
SF = 30712
CRC = 12
LOS = 0
LOF = 0
ES = 5
Latest 1 day time = 9 min 2 sec
SF = 30712
CRC = 12
LOS = 0
LOF = 0
ES = 5
Latest 15 minutes time = 9 min 2 sec
SF = 30712
CRC = 12
LOS = 0
LOF = 0
ES = 5
Previous 15 minutes time = 0 sec
SF = 0
CRC = 0
LOS = 0
LOF = 0
ES = 0
Previous 1 day time = 0 sec
SF = 0
CRC = 0
LOS = 0
LOF = 0
ES = 0
Showtime Drop Reason: 8000
Last Retrain Reason: 8000
Mode: ADSL2+
Channel: Fast
Trellis: U:ON /D:ON
Down Up
SNR (dB): 6.1 6.5
Attn(dB): 26.5 12.3
Pwr(dBm): 18.4 12.4
G.dmt framing
K: 95(0) 36
R: 14 0
S: 1 1
D: 128 1
ADSL2 framing
MSGc: 59 16
B: 94 35
M: 1 1
T: 4 3
R: 14 0
S: 0.2461 0.9762
L: 3542 295
D: 128 1
Counters
SF: 30712 30687
SFErr: 12 3562
RS: 7985122 0
RSCorr: 6592 0
RSUnCorr: 481 0
HEC: 12 1913
OCD: 0 0
LCD: 0 0
Drop Cells: 0
ES: 5 2392
SES: 0 0
UAS: 38 2778
AS: 492
INP: 2.02 0.00
PER: 16.00 16.10
delay: 7.87 0.24
OR: 32.49 10.92
Bitswap: 44 5
SF = 30712
CRC = 12
LOS = 0
LOF = 0
ES = 5
SF = 30712
CRC = 12
LOS = 0
LOF = 0
ES = 5
SF = 30712
CRC = 12
LOS = 0
LOF = 0
ES = 5
SF = 0
CRC = 0
LOS = 0
LOF = 0
ES = 0
SF = 0
CRC = 0
LOS = 0
LOF = 0
ES = 0
