Something happened to my (ADSL Max) line a couple of weeks ago, used to have ~2.5Mb/s sync stable (2Mb speedtest throughput after BT's IPProfiles screwed me over) now It's like this.
Attenuation hasn't changed, so seems like there's interference somewhere - even with a 14.5dB noise margin I've got a hell of a lot of errors. I used to be able to run on Fastpath but had to switch over to Interleave to stop the line dropping every few mins.
Any suggestions? I'm using an XTE-2005 filtered faceplate, Cisco 877 adsl router, and haven't made any internal wiring or phone changes.
Code:
Vendor ID: 'STMI' 'ALCB'
Vendor Specific: 0x0000 0x0000
Vendor Country: 0x0F 0x0F
Capacity Used: 99% 91%
Noise Margin: 14.5 dB 9.0 dB
Output Power: 16.0 dBm 12.0 dBm
Attenuation: 51.0 dB 31.5 dB
Defect Status: None None
Code:
Interleave Fast Interleave Fast
Speed (kbps): 1344 0 832 0
Cells: 206558801 0 18384748 0
Reed-Solomon EC: 11379 0 2835 44
CRC Errors: 3020 0 469 38
Header Errors: 2619 0 404 47
Total BER: 1559E-9 0E-0
Leakage Average BER: 1256E-12 0E-0
LOM Monitoring : Disabled
