Linix / Terminal Command help
must be doing something wrong:
kencs@Kencs-System:~$ sudo apt-get opera
E: Invalid operation opera
Any step by step advice as I dont understand the advice from the ubuntu forums etc...
thanks
It's step by step on the Ubuntu wiki.
Code:
deb http://deb.opera.com/opera/ stable non-free
wget -qO - http://deb.opera.com/archive.key | sudo apt-key add -
sudo apt-get update
sudo apt-get install opera
With no offense intended, .Kencs, you've already got a couple of threads running on the topic of installing software either directly using the .deb or via the apt-get or Synaptic package management interfaces. People have simply ended up re-posting here what has already been linked to or can be readily googled for :(
To expand on what BigglesPiP has just added,
Applications -> Accessories -> Terminal
Code:
echo deb http://deb.opera.com/opera/ stable non-free | sudo tee -a /etc/apt/sources.list
sudo apt-get update
Applications -> Internet -> Opera
Please give yourself a bit more of a chance lest you might find fewer responses in future, especially if an impression is given that advice which leads to the solution has been ignored.
Thanks all for replying. I have joined the Ubuntu forums to see if I can read up and learn something :) Its just the commands they seem to put me off a little but im slowly learning :)
Managed to get Conky installed on my netbook, when I run it in Netbook edition it is showing along the bottom, when I run in Desktop edition I cant see it.
Following a website instruction, it says to put the following into a config file:
background yes
use_xft yes
xftfont DejaVu Sans Mono:size=8
xftalpha 0.8
out_to_console no
update_interval 5.0
total_run_times 0
draw_shades no
# Create own window instead of using desktop (required in nautilus)
own_window yes
# If own_window is yes, you may use type normal, desktop or override
own_window_type override
# Use pseudo transparency with own_window?
own_window_transparent yes
double_buffer yes
default_color 586F86
color1 white
alignment bottom_left
gap_x 2
gap_y 2
#no_buffers yes
use_spacer yes
TEXT
$nodename:${color1}$kernel${color} up:${color1}$uptime${color} cpu1:${color1}${cpu cpu1}% ${cpubar 6,30 cpu1}${freq cpu1}MHz${color} cpu2:${color1}${cpu cpu2}% ${cpubar 6,30 cpu2}${freq cpu2}MHz${color} mem:${color1}$memperc% ${membar 6,30}${color} dsk:${color1}${fs_used /}/${fs_size /}${fs_bar 6,30 /}${color} load:${color1}$loadavg ${color} ip:${color1}${addr wlan0}${color} trafc:${color1}${downspeed wlan0}/${upspeed wlan0}Kb/s${color} bat:${color1}$battery
Which part of the code tells it to become a line and not a box? I want it to be a box but everything I have tried to change doesnt work. I have tried googling it and cannot find the answer Im looking for.
Your description is vague, but if I'm understanding your question right, the answer is: "All of it."
Just uninstall conky, it's beyond you for now I would say. You'll find it's a bit clunky even when it's fully set up.
Also, get it out of your head that everything must be done with a command. Most of ubuntu can be managed in the GUI.
