Hi, I have been given a GSF 650 carbon fiber stubby exhaust for my GSX 650F. Since they're essentially the same bike.
Everything lines up nicely, except for 1 problem. The end of the link pipe that clamps onto the bike exhaust only goes over a small part of the tube. Its about 1mm dia. too narrow to fit on the rest fully.
Can the metal flaps be sprised open a little more and then forced onto the end to make a seal, or is it a lost cause?
Thanks for your input
