Hi,
I have a laptop that I'm using to try and download a file, and the file is inside a log-in area. I've tested this on Opera and IE and get the same result.
When logged in and with the cursor over the file to click and prompt a download dialogue box, it brings up the text selection cursor instead of the hand/pointer cursor.
When you click, it then logs the user out.
I've tested it on my laptop using Opera and it works fine and prompts the download.
Any ideas? I'm sure it's something simple...
