15 May 2006 at 13:28 #1 FunkyT FunkyT Soldato Joined 27 Aug 2003 Posts 3,464 Can you remember how to link to a specific place on a webpage when quoting a URL?
15 May 2006 at 14:12 #2 Simebaby Simebaby Associate Joined 19 Oct 2002 Posts 206 Location Oop north - where it's grim... The page you're linking to needs a tag to define the point you want to link to. Then Code: <a href='http://www.somewebsite.com/page.html#section1'>link</a> #section1 being the name of the point above. Might want to move this to HG&P... Last edited: 15 May 2006
15 May 2006 at 14:15 #3 Vonhelmet Vonhelmet Caporegime Joined 28 Jun 2005 Posts 48,278 Location On the hoods You put #ANCHOR_NAME after the URL. This is assuming the page makes use of anchors, which is by no means guaranteed.
15 May 2006 at 14:26 #4 Moredhel Moredhel Soldato Joined 11 May 2004 Posts 4,790 Location Gloucester Anchor locations are defined by ID. So if you have <h2 id="sectionc">Title</h2> you could link to it by http://www.domain.com/path/to/page#sectionc It works for the ID of any element, so look out for IDs surrounding the content you want to link to.
15 May 2006 at 14:38 #5 FunkyT FunkyT Soldato OP Joined 27 Aug 2003 Posts 3,464 Thanks for the helpful replies. The damn page I'd like to link to doesn't seem to have anchors or IDs
