linking 2 psus together
Im not in the uk, can i not just join the green wires together and 2 black earth wires?
That's essentially what adapter does.
Though if you start cutting wires that's very likely to go bad with warranty.
With UK still belonging into EU you could buy it from them withotu any delivery hassle t oanother EU country.
Also OcUK's parent company, Caseking has it.
Its EAN code 5999094001077 also works in Google.
Also at least Thermaltake makes such adapter cable so you could look for it, if you live outside EU.
https://www.thermaltake.com/dual-psu-24pin-adapter-cable.html
