- 29 Sep 2003
- Newcastle upon Tyne
say I have an ADSL router with the modem built in. Is it possible to connect another router to the 1st one and have that route an internet connection to other PCs?
As long as you disable everything on it that makes it a router, that is.ns400r said:If you already have a second, spare router then it's neither complex nor expensive.
Is this implying the first router isn't? You will still (unless you have WDS on both routers) probably have to join both routers with a cable.mrochester said:i already have the 2nd router, plus the 2nd router is wireless.
Mr Sniper said:What make of routers have you got? I recently set this up to increase wireless signal across my house and it works like a charm (until i buggered up my second router and bricked it). The easiest way to do this is to find a function on your routers called RIP, it's a dynamic route finder basically.
Mr Sniper said:It just makes everything easier and less hassle, he could setup static routes if he wanted to. I used RIP because i'm lazy lol.
