Linking fan speed to GPU temperature
6 Jan 2013
Rollergirl
Question is predominantly aimed at those who cool their GPU with a custom loop. How do you control radiator fans to react to GPU temperature? Is SpeedFan the only option or can it be done another way?
Spec is:
6700k
Gene VIII
1080ti
PWM fans
https://www.overclockers.co.uk/ek-water-blocks-ek-cable-pwm-fan-adapter-for-gpu-50cm-wc-9d9-ek.html
Can plug that into the GPU header and control the fans using afterburner/precisionX
https://www.overclockers.co.uk/ek-water-blocks-ek-cable-splitter-4-fan-pwm-extended-wc-9cq-ek.html
Can also use this kind of cable to power the fans seperately if you're near the power limit.
That first cable, I assume it powers the fans as if they were GPU heatsink fans? That's absolutely perfect, I just wish I knew about it before I put my block on the GPU as I'd need to drain and strip it down now. :( I'll pick one up for future.
I use aquaero 6 (usb) and software sensor. Although I don't have a loop anymore I still use it to have my fans come up a few hundred rpm above idle when the gpu hits a certain temp (I.e gaming load), to help keep things cool.
I've just found a thermistor cable that I had and have plugged it into the motherboard sensor socket. I can now control any chassis fan based on this sensor, and I've slid it into the gap between block and PCB. It's working a treat.
It's interesting to see how others are dealing with this because not very many motherboard's have this facility, in fact I didn't know mine had it until I dug into the manual.
aquaero 5LT linked to AIDA64, used it for three AIOs, (SLI plus CPU), and case fans. Worked well but was really fussy with fan choice.
