Linking to a port
18 Jan 2006
Norwich
Very stupid question, I must have missed something here :p
I've added a landing page to my server for remote admin duties, this is a simple HTML page containing a few links, no fancy CSS etc.
I'm trying to link to a port number, like this:
Code:
http://SERVER:8112
I'm getting a forward slash between the end of the server URL and the port number, no matter how I format my link, so the page looks like this:
Code:
http://SERVER/:8112
Anyone care to point out what I've missed :)
-Leezer-
Are you using any sort of framework?
edit: or are you using any .htaccess files?
Nope, absolute standard HTML file, no frameworks or .htacess:
Code:
<HTML><HEAD>
<b><u>Web Interfaces</b></u>
<a href="http://unimatrix-001/NZB/index.php">HellaNZB web interface</a><br>
<a href="http://unimatrix-001/backuppc">BackupPC web interface</a><br>
<a href="https://unimatrix-001:10000">Webmin Login</a><br>
<a href="http://unimatrix-001:10001">Azureus web interface</a><br>
</body></html>
This is as far as I've got really :)
Might get round to adding an uptime/ status widget, but all I'm really after is a simple landing page with links to all the management functions. (This way I can simply bookmark a single page on the phone)
Not supposed to be pretty or fancy, just needs to do the job properly.
-Leezer-
Works fine for me? :confused:
<a href="www.test.com:12345">Test</a>
*click*
"Error!
The address type is unknown or unsupported
You tried to access the address www.test.com:12345, which is currently unavailable. Please make sure that the Web address (URL) is correctly spelled and punctuated, then try reloading the page."
What browser is this messing up in?
Code:
http://SERVER:8112
Code:
http://SERVER/:8112
-Leezer-
Does it still work?!
@ Sin_Chase - You need the protocol at the start.
