Linksys router/DHCP/IP settings problem
18 Feb 2006
Basically, at lunch I set my PC to have a static IP address and turned DHCP off as this was causing problems last night. This worked fine until 3 today where the internet stopped working and only a few sites worked - others timed out. This is a usual occurance when I set a static IP with DHCP still on (out of the DHCP range)
I then went to turn DHCP back on again to find I couldn't connect to any sites on the internet (but there was activity through the internet still :/.) which is where I am still at. No device can access the internet.
The internet works fine through my old Speedtouch.
Any ideas? I know I am being a bit vague but I don't really know whats wrong. :/
Thanks, Trif.
Thank you Linksys for the reset button. Internet works on this router. How do I go about setting static IP's though. :(
