Hi guys,
My g/f just bought a Linksys WAG200 to replace her Netgear DG834 that eventually gave up the will to live....anyway, from installation it worked great, however when there is no internet traffic for a while, ie all machines connected to the router are turned off, the internet LED flashes red and no internet connection can be established even though DSL is green, she can login to the router and change settings etc etc, so its not locking up as far as I can tell.
If she then does a 'hard' reboot everything is back up and running until the same thing happens again when she goes to bed or leaves the PCs off for a while.
She's been in contact with Linksys and shes now running a 'beta' version of the firmware but the same problem happens, unfortunately she is with Tiscali and they are about as much use as a chocolate frying pan when it comes to helping you out with non-standard issue hardware.
The only thing I can think of doing is to change the MTU from Auto to a set value of 1472 and see if that works, anyone have any other ideas, maybe I'm missing something simple
TYIA
TYIA
