- 4 Oct 2006
- Leighton Buzzard, UK
Hi I've got one of the above & my wireless range is really short at the moment.
I've got the most recent firmware & have tried all the different channels to see if that made a difference to the range, currently 6 & 8 are the most powerful. However with a direct line of sight I can lose connection about 10m away & if there is a wall in the way this cuts down to about 3-5m distance. I have my pc linked via ethernet cable & a second PC the other side of the house which had wireless access, 2 walls about 15m away which cannot see the router.
Anyone recomend any settings that need to be changed to boost the range as i'm sure it should be better than my old BT router!
