== Linksys WRE54G 54Mbps Range Expander In Stock Tomorrow ==
9 Nov 2003
Leeds
Expand the range of your wireless network! The Linksys Wireless-G Range Expander is the easy way to increase the effective coverage of your wireless network. Unlike adding a conventional access point to your network to expand wireless coverage, the Wireless-G Range Expander does not need to be connected to the network by a data cable. Just put it within range of your main access point or wireless router, and it "bounces" the signals out to remote wireless devices. This "relay station" or "repeater" approach helps to build wireless infrastructure by driving signals into even those distant, reflective corners and hard-to-reach areas where wireless coverage is spotty and cabling is impractical. The Range Expander is perfect to help cover large areas in multi-story homes, warehouse environments, public spaces, wireless "Hot Spots", and outdoor venues -- anywhere you need extra coverage for your wireless network.
- Save on wiring costs - no wired connection to your network necessary
- Extend your wireless signal into hard-to-reach areas
- Compatible with both Wireless-G and Wireless-B networking clients
£49.99 inc VAT.
BUY NOW
