Linksys WRT54G + Tomato firmware install problem
  • Thread starter Thread starter Guv
  • Start date Start date
Guv
Guv
24 Oct 2002
Warwickshire
I was running sveasoft on my router but thought I'd give tomato a try so installed it which the router told me was sucessful, however I can't access the router now.
I've tried 10.0.0.1 which it was before, 192.168.0.1 and 192.168.1.1
I've also tried resetting the router using the button on the back.
Any ideas?
Do you not have to put it back to the default firmware before putting another 3rd party firmware on?
if you've flashed with tomato and it installed
take out the power cable
hold the reset button for 60 seconds, then release, now plug back in, and try 192.168.1.1 with the ethernet cable plugged in
admin
root
think that's the name & password
thanks for the help guys
I managed to get access with wireless only, but couldn't get an IP with the wired ports or get an IP from my ISP.
So I put sveasoft back on which worked but thought I'd give tomato another go and realised I'd used the wrong version before! oops!
Anyway all working fine now I used the right version :)
