Hi, i just ordered the Linksys router and Netgear adapter because i needed to which to wireless. Im on vigin, will it all work fine?
I heard the Netgear WG111 has a few problems with vista, so im about to reinstall xp on the computer that needs wireless, the other two computers will be hooked up via cable. Should this all be ok?
Do i need anything else?
Do i need to enter any information into the router or will the modem have all that? I heard i needed a few things if i wanted to set up a static ip address is this true?
Cheers
Cheers
