Linksys WRT54GL
  • Thread starter Thread starter Xon
  • Start date Start date
Xon
Xon
18 Oct 2002
Malta
Hi all
I have a couple of questions about this unit wonder if you guys could help!
Are the antennas detchable? Will it power a 14db antenna if so?
Also, does it support PPPoE ?
Thanks!
Xon said:
Hi all
Thanks!
Yes they are detachable, yes it will power a 14dB antenna if it has the correct fitting and yes it does support PPPoE.
Awesome, thanks :)
tolien said:
Depends what you mean by PPPoE - bear in mind it doesn't have an ADSL modem.
It will be connected to a modem (speedtech 530v6 to be exact) so it should work :) I'm going to upgrade from a d-link 524 flashed to 624 so hopefully it'll be a better router.
