Linksys WUSB54GS help static IP ?
18 Oct 2002
Nottingham
Hello,
Trying to a a linksys wusb54gs wireless usb adapter working with a linksys wrt3OON router.
Laptop on wireless working fine no problems with internet.
Unable to get desktop to connect through the wusb54gs.
Reinstalled wusb54gs with latest drivers <not using linksys connection program using built in windows xp wireless>
lists wireless connection with limited or no connecitivity.
i want to no how to setup the desktop pc with a static ip and dns address to work with the router ? to solve the program and get on the net.
Thanks Ben :)
Use Windows Zero Configuration Utility.
The software Linksys provides causes a hell of a lot of errors in transmission.
Assuming your router's IP is 192.168.1.1;
Set your DHCP IP range to 192.168.1.50 and upwards on the router.
Set your Static IP on the wireless adapter to any number between 1 and 50. Not including them though.
Your DNS and Gateway are the router now, so that'll be 192.168.1.1 in both cases. Subnet mask is 255.255.255.0
Happy hunting!
