LINQ question
27 Jan 2005
S. Yorks
I have the following code
Code:
using (GeneratedCode orgcontext = new GeneratedCode(service))
                        var retrievedProducts = (from p in orgcontext.ProductSet
                                                 join qd in orgcontext.QuoteDetailSet
                                                 on p.ProductId equals qd.sp_SellingProductId.Id
                                                 where qd.QuoteId.Id == entity.Id && p.orb_ParentProductid != null
                                                 select new
                                                     product_name = p.orb_ParentProductid.Name
                                                 }).Distinct();
                        var _txttowrite = string.Empty;
                        if (retrievedProducts != null)
                            // for each item returned write the output to a string.
                            foreach (var item in retrievedProducts)
                                if (item.product_name != "")
                                    if (String.IsNullOrEmpty(_txttowrite))
                                        _txttowrite = item.product_name;
                                    else
                                        _txttowrite += ", " + item.product_name;
                        // Write data to current quote.
                        Quote currentQuote = (Quote)service.Retrieve(Quote.EntityLogicalName, entity.Id, new ColumnSet(false));
                        currentQuote.ancon_quoteproducts = _txttowrite;
                        currentQuote.ancon_activatedate = DateTime.Now;
                        service.Update(currentQuote);
It all works as expected however one of the returned values in the query is a null how can I filter these out or deal with these, not touched programming for a short while and cant seem to crack this.
regards,
Matt
suffix with
Code:
&& p.orb_ParentProductid.Name != null
Now that that is done, we can look at refactoring the rest of your code. :)
All of this:
Code:
                                    else
can become:
Code:
var _txttowrite = retrievedProducts == null
  ? string.Empty
  : string.Join(", ", retrievedProducts.Where(x => !string.IsNullOrWhiteSpace(x.product_name).Select(x => x.product_name));
Have updated the code to
Code:
                                 where qd.QuoteId.Id == entity.Id && p.orb_ParentProductid.Name != null
                                 select new
                                  }).Distinct();
This code fails with a "Invalid 'where' condition. An entity member is invoking an invalid property or method"
any ideas?
With this line
Code:
var _txttowrite = retrievedProducts == null? string.Empty: string.Join(", ", retrievedProducts.Where(x => !string.IsNullOrWhiteSpace(x.product_name).Select(x => x.product_name));
I get an error in the IDE at the !string.IsNullOrWhiteSpace(x.product_name).Select(x => x.product_name)); when I hover over it says bool does not contain a definition for select accepting a first argument of type bool.
regards,
Matt
ah yes, it won't work with nested properties. And an internet point to Haircut :p
Also you didn't quite do it right as I meant literally suffix as in copy and paste that onto the end not replace the ending.
Anywho.. try replacing the entire method with this:
Code:
var retrievedProducts = orgcontext.ProductSet
	.Join(orgcontext.QuoteDetailSet,
		p => p.ProductId,
		q => q.sp_SellingProductId.Id,
		(p, q) => p.orb_ParentProductid.Name)
	.Where(s => !string.IsNullOrWhiteSpace(s))
	.Distinct();
var currentQuote = (Quote)service.Retrieve(Quote.EntityLogicalName, entity.Id, new ColumnSet(false));
currentQuote.ancon_quoteproducts = string.Join(", ", retrievedProducts.Where(x => !string.IsNullOrWhiteSpace(x.product_name).Select(x => x.product_name));
Thanks for all your help.
Tried that code and x.product_name is erroring with
Error 1 'string' does not contain a definition for 'product_name' and no extension method 'product_name' accepting a first argument of type 'string' could be found (are you missing a using directive or an assembly reference?) E:\MH Test Software\C#\MH-Plugins\Plugin_Project\Plugin_Project\PreQuoteUpdate.cs 59 136 Plugin_Project
Also is this line
missing a closing bracket?
Matt
yes and yes. What a wally, eh? :)
Both errors should be fixed by changing "string.IsNullOrWhiteSpace(x.product_name)" to "string.IsNullOrWhiteSpace(x))"
Note the extra closing parenthesis.
Have updated the quote and there are no errors in the IDE.
Code:
		                                        p => p.ProductId,
	                                            .Distinct();
                        currentQuote.ancon_quoteproducts = string.Join(", ", retrievedProducts.Where(x => !string.IsNullOrWhiteSpace(x)).Select(x => x));
When I run the code I receive the error Invalid 'Where' condition. An entity member is invoking an invalid property or method.
regards,
Matt
In your linq statement, although I find it hard to follow where are you filtering for the QuoteId.Id == entity.Id?
Or am I being stupid?
regards,
Matt
Updated code to
Code:
                        p => p.ProductId,
                        .Distinct();
                        currentQuote.ancon_quoteproducts = string.Join(", ", retrievedProducts.Where(x => x!= null).Select(x => x));
Builds in IDE, but when I run I get:
"Invalid Where condition. An entity member is invoking an invalid property or method."
regards,
Matt
There's the other IsNullOrWhiteSpace that needs replacing.
Dude.. I'm starting to feel like I am chewing your food for you here.
Thanks for all your help, as said above I am back looking at code after a break, however, code is now:
Code:
                        p => p.ProductId,
                        //.Where(s => !string.IsNullOrWhiteSpace(s))
                        .Where(s => s!= null)
                        .Distinct();
When it runs it fails with the message:
Invalid 'where' condition. An entity member is invoking an invalid property or method.
regards,
Matt
This line:
Code:
I dont think you can check if the whole object is null like that, you need to check for one of the specific attributes.
Something like:
Code:
.Where(s => s.ProductId != null)
What have you tried so far?
It seems that you're not actually debugging anything yourself and just posting the errors up here.
Are you using Dynamics CRM?
Googling that error message suggests it's coming from that.
I'm not sure what the LINQ query provider is like for that, but it's entirely up possible (though I would have thought unlikely) that it doesn't support comparison with null.
Thanks for the reply yes it is Dynamics CRM so not very easy to debug with unfortunately - or at least I am yet to find a way to do it.
I have gone back to my original code, which is:
Code:
                                                 select new
                                                 });//.Distinct();
                        var _txttowrite = "";
                                 //for each item returned write the output to a string.
                            foreach (var item in retrievedProducts.Where(a => a.product_name != null).Select(a => a))
                                else
This line I have modified:
Code:
from
Code:
from a google session and Stackoverflow suggests here: http://stackoverflow.com/questions/...set-to-an-instance-of-an-object-c-sharp-error
running this new code I get the error:
The method 'Where' cannot follow the method 'Select' or is not supported. Try writing the query in terms of supported methods or call the 'AsEnumerable' or 'ToList' method before vcalling unsupported methods.
I remember having issues like this previous with LINQ but like I said it is a while since I have worked with LINQ.
regards,
Matt
