LinqQ Query
30 Mar 2004
West Wing
Hi,
Im joining together 2 lists in C# with this query, which works OK.
Code:
var joinedList = from a1 in custRefs
                             join a2 in itemRefs
                             on a1.id equals a2.id
                             select new { a1.id, a1.idname, a2.itemvalue };
However, in my list there are are always 2 identical IDs, each with a different NAME. I want my Linq joined list to skip the item if its already been joined to a itemValue in itemRefs.
The Lists
custRefs:
ID, NAME
abc1, daytimeref
abc1, nighttimeref
bcd, daytimeref
bcd, nighttimeref
xyz, daytimerefer
xyz, nighttimeref
itemRefs:
ID, VALUE
xyz, 4512.0
bcd, 221.9
abc1, 6612.3
This is the result I want:
abc1, daytimeref, 6612.3
abc1, nighttimeref, 6612.3
bcd, daytimeref, 221.9
bcd, nighttimeref, 221.9
xyz, daytimerefer, 4512.0
xyz, nighttimeref, 4512.0
Its possible there is a much simpler way to do this than the way I am currently doing it. Thanks!
OP
30 Mar 2004
West Wing
Ah sorry, I should have been clearer. This is the result I am currently getting with the query above:
xyz, daytimeref, 4512.0
You can see its returning the first NAME where the ID is joined.
25 Jan 2009
UK
Having a slow morning so recreated your lists. How are they stored? I made them KeyValuePairs so I was able to re-use the same Key:
Code:
        public static List<KeyValuePair<string, string>> custRefs = new List<KeyValuePair<string, string>>();
        public static List<KeyValuePair<string, string>> itemRefs = new List<KeyValuePair<string, string>>();
        public static void SetUpLists()
            custRefs.Add(new KeyValuePair<string, string>("abc1", "daytimeref"));
            custRefs.Add(new KeyValuePair<string, string>("abc1", "nighttimeref"));
            custRefs.Add(new KeyValuePair<string, string>("bcd", "daytimeref"));
            custRefs.Add(new KeyValuePair<string, string>("bcd", "nighttimeref"));
            custRefs.Add(new KeyValuePair<string, string>("xyz", "daytimeref"));
            custRefs.Add(new KeyValuePair<string, string>("xyz", "nighttimeref"));
            itemRefs.Add(new KeyValuePair<string, string>("xyz", "4512.0"));
            itemRefs.Add(new KeyValuePair<string, string>("bcd", "221.9"));
            itemRefs.Add(new KeyValuePair<string, string>("abc1", "6612.3"));
I then called this method:
Code:
        public static void JoinLists()
            var joinedList = from item1 in custRefs
                             join item2 in itemRefs
                             on item1.Key equals item2.Key
                             select new { item1.Key, item1.Value, item2Value = item2.Value };
I get the result you want without issue.
